1978 Clearance for 2l Golf Motor
Francois Swart
What model do you have?: 1964
Post by Francois Swart »
I measured the clearance under the load bay of the crewbus and it is 395mm from the centre of the spigot shaft to the bottom of the support beams under the load bay.
The 2L Golf motor, if it stands upright measures 515mm from the centre of the clutch plate to the top, a difference of 120mm. Do you fit the engine at an angle to get it in below the load bay or do you increase the height of the load bay (which i do not really wan to do).
Can anybody help?
oldschoolgp
What model do you have?: 1976
Re: 1978 Clearance for 2l Golf Motor
Post by oldschoolgp »
You need to cut and increase the height of the load bay
I have an extra caravelle lid
Pm me
Has thanked: 36 times
Been thanked: 50 times
Post by flatfourfan »
I think with the angle that it sits, on my 2.0 motor it dropped it by about 25mm due to the angle, but I think that the lid needs to be lifted as well for a bus.
splitfan
Has thanked: 46 times
Been thanked: 26 times
Post by splitfan »
VW Ran a 1.8 motor in the t3 busses that sat at a angle ,(no raised engine lid) I cant remeber now whether the bellhousing was different or if it had a adaptor to accomadate the angle on the gearbox side , I do know they ran a different sump and oil pick. These are impossible to find as they were only fitted to 1.8 t3's.
