1978 Clearance for 2l Golf Motor
Posted: Mon Jan 28, 2013 5:06 pm
I measured the clearance under the load bay of the crewbus and it is 395mm from the centre of the spigot shaft to the bottom of the support beams under the load bay.
The 2L Golf motor, if it stands upright measures 515mm from the centre of the clutch plate to the top, a difference of 120mm. Do you fit the engine at an angle to get it in below the load bay or do you increase the height of the load bay (which i do not really wan to do).
Can anybody help?
Can anybody help?
