Questions - ??? - & Answers - !!!
- JohnCloete
- What model do you have?: 1966 Type 3 SquareBa
- Has thanked: 42 times
- Been thanked: 4 times
Hallo all you good People
Is there a visible difference between a 1600cc and 2000cc Bus engine
Is there somewhere in the vin number a digit that indicates what my Bus's engine size should be
Also, what spec changes are there on a 2000L Executive compared to the standard and what year did they surface
Regards
"Drip"
Regards
"Drip"
John
0734897477
. . . . . . . . . . . . . . . . . . . . .JESUS IS LORD OF ALL
0734897477
Re: Questions-Questions
yes, they are two totally different engines
1600 is a T1 engine aka - beetle engine
2000 is a T4 engine, aka bus engine.
Yes, the 1600 was used in some busses.
Obvious way to tell is the T4 has the fan mounted on the crank, not belt driven like a T1. Also the inlet ports on a T4 are about 10cm apart from each other where on the T1 they are about 3cm apart if it is a twin port, otherwise there is only 1 port.
The T4 also has an oil filter
- JohnCloete
ThanX Tony,
That there in the engine "Bay" is now definately a 1.6 tp, I also know now. That other motor coming is a 2.0.
Now the next thing is, how do I change this setup to electronic ignition, is this difficult to do...................
"Drip"
"Drip"
John
0734897477
0734897477
just use the distributer and black box from a 1.9 combi engine (watercooled flat 4)
- JohnCloete
Is this items that I will be able to get from the guys at goldwagen, or will it be on used parts
John
0734897477
0734897477
- Has thanked: 424 times
- Been thanked: 542 times
Easy to find at Scrap Yards....JohnCloete wrote:Is this items that I will be able to get from the guys at goldwagen, or will it be on used parts
- Sambabus
- Short Block
- Has thanked: 39 times
- Been thanked: 14 times
post a pic of your engine. your bus is a late bay, post 1972, and came standard with a T4 engine......I
- JohnCloete
3 Pics have been added to the gallery, I have no idea how to get them here. That ok?
John
0734897477
0734897477
- splitfan
- Has thanked: 46 times
- Been thanked: 26 times
That is a type IV engine probably a 2.0
- JohnCloete
ThanX, from what TonyZ said, up-Top, the difference in the distance on the inlet port should tell them apart. I had a measure with the eye and that is definately not 10cm but rather 3cm. I am posting a pic to show you guy's
John
0734897477
0734897477
- Sambabus
- Short Block
Tony also told you about the cooling fans location, ......your engine is a type 4.
That there motor is be a type 4 for sure, what is not so sure, is that it may be a 1800 cc or 2000 cc.
But looking at is it would seem it is a 1800 cc, BUY not sure......
- JohnCloete
Ok, the motor is out and this is the inlet ports
John
0734897477
0734897477
- JohnCloete
Some more pictures in the "Project's"
John
0734897477
0734897477
That is defintely a Type 4 engine.
I dont know the engine numbers and what they mean, but its either 1700, 1800 or 2000cc
