Constant Velocity universals Explained ?? sort of
Warwick-Lowlight
Post by Warwick-Lowlight »
As any of you good people out there have experienced before the above has had me in a real confused state
First attempting to take these things off is a real test of why does this spanner/ tool not work in the little recess provided
after getting them off and cleaning each one individually and not muddling them up as the book says
This is were the literature gets seriously confusing
Some have a groove some have many groves some have no groves some are recessed and some not
Anyhow with all this grooving and recessing I thought I would post a few pics with some of the explinations taken from the "Haynes repair manual "
Here is the single groove oke
Part # 211 501 331- Lobro with vw logo stamp
Date stamp 6/76 ??
Here is the recess one
Part # also 211 501 331- Lobro with vw stamp
Date stamp 07/67
Please do correct me if I am wrong
Grooved version the groove faces the flange or outside - this outside being where the circlip goes on
For the recess one
Recess faces the boot
The other parts worth noting is not to tilt the joint more than 30 degrees cause it can fall apart
also there is only one way of putting it back together again
Balls need to clik in and if correctly installed then should be easy movent hense the thing wanting to fall apart when tilted
If the joint is tight then rotate the inner portion
Should have large gap in the outer channels to a small gap in the inner channels
Maybe someone more intelegent than myself can explain why there is a wrong and a correct way as the measurements all seem the same on the inner and outer sides
Is the centrifugal force driving the balls out or in when movement happens
Lank :?
riaanj
Been thanked: 41 times
Re: Constant Velocity universals Explained ?? sort of
Post by riaanj »
I recently replaced my beetle's CV's, the IRS suspension on my '73 beetle uses 4 CV joints, I found out they are exactly the same as the City Golf inner CV's and bought 4 @ R285-00 from Goldwagen, took me about 4 hours to strip, paint the shafts & install the new units. (after much swearing at the PO damaging 3 of the bolts, me cutting the one off and getting/using the right 12 spline tool for the rest). 8)
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
I cant comment on the CV. But for the sake of being pedantic and giving out more useless information, that it isnt a 12 spline tool... it actually is a triple square tool
Has thanked: 424 times
Been thanked: 542 times
Tony Z wrote:I cant comment on the CV. But for the sake of being pedantic and giving out more useless information, that it isnt a 12 spline tool... it actually is a triple square tool
Or you can just call it on its right name, a Trox key. .... :wink:
Runs into corner and awaits flying tools... :oops:
that isnt a torx... shame on you Herman
Tony Z wrote:that isnt a torx... shame on you Herman
Hey !! Tony, you sharp tonight.. ...... :lol: :lol: :lol:
PS. official description;- XZN, 12-Pointed Spline (Triple-Square) Socket-Screws
Sorry must be the new tablets........ :lol:
riaanj
Post by riaanj »
Whatever man, at least you knew what I was refering to.. Herman is right with the XZN description, I checked my workshop manual..
Honda CBR600RR
Honda CBR600F4
