Constant Velocity universals Explained ?? sort of
Posted: Wed Mar 06, 2013 3:54 pm
As any of you good people out there have experienced before the above has had me in a real confused state
First attempting to take these things off is a real test of why does this spanner/ tool not work in the little recess provided
after getting them off and cleaning each one individually and not muddling them up as the book says
This is were the literature gets seriously confusing
Some have a groove some have many groves some have no groves some are recessed and some not
Anyhow with all this grooving and recessing I thought I would post a few pics with some of the explinations taken from the "Haynes repair manual "
Here is the single groove oke
Part # 211 501 331- Lobro with vw logo stamp
Date stamp 6/76 ??
Here is the recess one
Part # also 211 501 331- Lobro with vw stamp
Date stamp 07/67
Please do correct me if I am wrong
Grooved version the groove faces the flange or outside - this outside being where the circlip goes on
For the recess one
Recess faces the boot
The other parts worth noting is not to tilt the joint more than 30 degrees cause it can fall apart
also there is only one way of putting it back together again
Balls need to clik in and if correctly installed then should be easy movent hense the thing wanting to fall apart when tilted
If the joint is tight then rotate the inner portion
Should have large gap in the outer channels to a small gap in the inner channels
Maybe someone more intelegent than myself can explain why there is a wrong and a correct way as the measurements all seem the same on the inner and outer sides
Is the centrifugal force driving the balls out or in when movement happens
Lank
Date stamp 6/76 ??
Date stamp 07/67
For the recess one
Lank
