sean wrote:1. You got the incorrect oil pressure switch fitted
2. Theres no seal where your spark plug lead enters through the cooling tin.
3. The original clips to hold your spark plug leads in place are missing, air will escape out those existing holes.
1. whats the difference between the switches?
2. huh? what does that look like?
3. the ones on the fanhousing?
I got reverse on the gearbox. Didnt do a thing, got in the kombi Saturday and all gears were there including reverse. Asked my father and he swears he didnt touch a thing since we got the gearbox in two weeks ago. I did however forget to lock the garage, it was open for two weeks
with wheels and everything free for the taking.Maybe someone came in and fixed it.
retrovan wrote:Nice job Splitz....
If I was you, I would get the bridge fuel pipe that goes to the other carb, down from there and run it at the bottom below the fan, you do not want it come loose and get sucked in to the fan. ..
Cable tie it down with the others at the bottom. will be safer there.
Slow down, now, you will be done with your 56 before me with my 56.....
Will look into that...
Its not for the 56, but for the split. 56 has been untouched in ages. Need to get the kombi running and finished before going on with the 56.
