Type 1 gearbox upgrade to Porsche 5 speed
Qkickslvr
What model do you have?: Type 1 1976
Post by Qkickslvr »
Just thought it was a interesting read.
http://www.aircooled.net/vw-transmissio ... onversion/
riaanj
Been thanked: 41 times
Re: Type 1 gearbox upgrade to Porsche 5 speed
Post by riaanj »
Qkickslvr wrote:Just thought it was a interesting read.
Interesting, wonder what such a conversion would cost?
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
Has thanked: 45 times
Been thanked: 208 times
Problem is that, while used Porsche parts are abundant and cheap in the US, they are scarce and expensive in this country. The easiest acvw to convert to Porsche transmission is the 411/412 series. This is because the shift shaft is more or less in the same position. (At the bottom).
Another option for local type 1/ type 3 applications would be the Berg 5-speed conversion, as this can be done while retaining the swing axle suspension.
Has thanked: 19 times
Any one of them will cost you more than you want to spend
A Mainshaft is R20K now a Gene Berg 5 will easy cost you R70K :shock:
Bugger wrote:Any one of them will cost you more than you want to spend
excluding the special shifter and the body modifications....
dont forget, the berg kit puts 5th gear ahead of reverse, i.e. next to 1st
Has thanked: 425 times
Been thanked: 543 times
Tony Z wrote:
Bugger wrote:......dont forget, the berg kit puts 5th gear ahead of reverse, i.e. next to 1st
And anyone that has done any racing, will know, that could lead to an very expensive mistake at speed... :shock: :shock: :shock:
