Good day esteemed fellow vw fans,
Kindly assist me in identifying these parts:
1. Engine with code SFDR.
2. Engine with code SFH.
3. Gearbox with code SFAS.
4. Gearbox with code 7229756 and no letters. Looks almost identical to the SFAS box.
5. Gearbox with code SFAB.
A question. Is there a way to check engine and VIN numbers before buying?
I.e. that it is not stolen.
Andre
0723714363
Gearbox codes
Re: Gearbox codes
Andrej wrote:Good day esteemed fellow vw fans,
1. Engine with code SFDR.-------------------------------------------------------------------------------- reconditioned by VW at one stage
2. Engine with code SFH. ------------------------------------------------------------------------------ 1500 single port
3. Gearbox with code SFAS.-------------------------------------------------------------------------------late 1600 tinport
4. Gearbox with code 7229756 and no letters. Looks almost identical to the SFAS box.---------- not Identical the clutch fork lever is bent inwards and it is a 1200 box
5. Gearbox with code SFAB. ------------------------------------------------------------------------------- late model 1300 transmission with thrust bearing guide tube
Andre
0723714363
Tjopar
Re: Gearbox codes
Good day all,
Where do one find a breakdown of the gearbox codes.?
My gearbox is AC 2588744 SF.
Also any one who can refer me to a Bearing supplier that can help with Gearbox bearings.? I need bearings but the numbers I have does not align with any from SKF, FAG, BMG...
Best regards
Paul
Best regards
Paul
- Has thanked: 141 times
- Been thanked: 100 times
Re: Gearbox codes
According to this page https://www.limebug.com/how-to-guides/view/32
The AC means your gearbox is for a 1500 Beetle. I would assume the SF is for South Africa.
Re: Gearbox codes
Tjopar wrote: Fri Jun 18, 2021 11:12 am Good day all,
Best regards
Paul
www.buggertransmissions.co.za
I can help with some bearings 0826008663
