66 ghia
62vwbeetle
Oil Seal
What model do you have?: 62,66,69
66 ghia
Post by 62vwbeetle »
So I have a 66 ghia in my garage and on Sunday I started to play, new ignition in , new voltage regulator as the little red light was on. Fired her up runs like dream but little red light still on grrrrrrrrr, time for alternator to come out , oh well fixing obvious isn't always the answer
62vwbeetle
Oil Seal
Re: 66 ghia
Cleaned and painted wiper Arms and put new blades too, got quotes to refurb my sprint stars today felt like night 1 in pollsmoor prison !
John Alves
Been thanked: 48 times
Re: 66 ghia
Post by John Alves »
is the little red light not the oil pressure warning light?
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
62vwbeetle
Oil Seal
Re: 66 ghia
Good question it's the one on the left and battery runs flat Am I wrong could it be oil
Pressure and I am assuming it is charging system
John Alves
Re: 66 ghia
red is oil green is charging unless someone has switched the wires
1968 1500 SP Beetle
62vwbeetle
Oil Seal
Re: 66 ghia
ok its the one on the Left hand side as you look at the guage - internet tells me it is not oil
Re: 66 ghia
switch the ignition on
it should come on
go to the engine
take the wire off the oil pressure sensor and hang it in the air
check the light again
if it is off, then it is the oil pressure light
double check by plugging back in and checking if light comes back on
62vwbeetle
Oil Seal
Re: 66 ghia
Heheh good advice thanks man
