Type 4 electric cooling
- marius 58 bug
- What model do you have?: 1958 beetle
- Has thanked: 3 times
- Been thanked: 5 times
I noticed there is some type 4 topics going around I found this pic on the net and would like to know what you type 4 gurus think about it
If it's to low you to old
- 4agedub
- Has thanked: 4 times
Re: Type 4 electric cooling
I think it can work if the fan can supply enough cfm.
From what I could find on the net the std beetle fan produces
A good 12" electric fan can produce:Looks like ~1700-1800 CFM with a doghouse fan and std pulley, assuming no slippage, 5000 crank RPM.
Electric Fan, Single, 12 in. Diameter, Reversible, 2,300 cfm, Black, Plastic, Kit
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
if you do more probing into that car, you will find it isnt a street driven car, but is used for short course "auto cross" events.
- Has thanked: 45 times
- Been thanked: 208 times
Big problem is air pressure. The standard type 4 fan pumps 800 litre per second at 4600 rpm, (vw's spec). This is at a relatively high pressure, to get this much air to flow past the small gaps between the cooling fins. Aircooled vw engines needs lots of cooling air pressure.
A typical electric radiator fan is not designed to work against that kind of back pressure. Those designed for that kind of pressure needs plenty energy. More than the alternator can supply.
Other problem is efficiency. The typical automotive alternator's efficiency can be as low as 50% at full load. More a type of "cost effective domestic" class design. Look at how relatively thin it's stator wiring is, (often under 2mm), compared to say house wiring rated at 55-100 amps. An alternator relies on lots of cooling air to prevent that thin wiring from burning out. Like a domestic vacuum cleaner, that generates more waste heat than mechanical power...
Add to that the losses of the electric fan.
Best efficiency is by direct mechanical drive.
Watercooled cars use electric fans because:
1) Many of them have transverse engines and it is difficult and expensive to change mechanical shaft drive through 90 degs. (think some early Peugeots tried this with a loong belt and lots of pulleys). Most heavy duty longitudinally engine mounted bakkies and 4x4's still use mechanical fan drive.
2) ease of regulating cooling by changing fan speed.
3) radiators designed for electric fans are of low air restriction, large surface area type.
- IMPI
- Been thanked: 78 times
The beetle and type four takes about 4 hp to turn the stock fan there is just no way to get 4hp from 12v
- riaanj
- Has thanked: 6 times
- Been thanked: 41 times
This is obviously why a turbo is not electric either, you can't get decent pressure from the limited resources & space in a car..Dawie wrote:Big problem is air pressure. The standard type 4 fan pumps 800 litre per second at 4600 rpm, (vw's spec). This is at a relatively high pressure, to get this much air to flow past the small gaps between the cooling fins. Aircooled vw engines needs lots of cooling air pressure.
(And when I say a turbo I mean the turbine is not an electric fan)
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
Honda CBR600RR
Honda CBR600F4
- 4agedub
Electric assisted turbo prototypeThis is obviously why a turbo is not electric either
- Been thanked: 322 times
Electrically "assisted" being the operative word. That "assistance" is probably about reducing turbo lag, but you can see the turbio is still exhaust driven because the electric drive alone can't power the turbo at full power.
- 4agedub
You are correct. It is only assisted to reduce lag.
- sarel.wagner
- Pushrod
- What model do you have?: T1 x 4, Split SCwide
- Facebook: http://www.facebook.com/sarel.wagner
- Been thanked: 2 times
If they clever, the waste under no boost conditions can turn that thing into a generator.....
Rgrds
Rgrds
What other people think of you is none of your damn business
or if they are even more clever, they can install a turbine that is way too large and use it to regulate boost pressure by using it as a generator.
Kers system?
Kers system?
- Ron&Gill
- Been thanked: 21 times
Except for the loss of power due to exhaust back pressure.
4hp is 250A at 12 Volts. That's kinda heavy...
