Karmann Ghia headlights problem
- Cogita
- Oil Seal
- What model do you have?: 63 Beetle
- Facebook: https://www.facebook.com/roscoe.jacobs
- Has thanked: 67 times
Hi guys
Im sitting with a bit of a problem
When I got my Ghia it had one proper looking Karmann Ghia headlight and one flat one (golf maybe).
I recently got hold of 2 headlights which ressemble Karmann Ghia headlights, even came with the original chrome headlight trim. One says Lucas on the lense.
Problems:
-They are both sealed beam headlights and shine very dim, so I cant replace the bulbs.
-Im worried that they might be 6v and might blow.
Any ideas?
Roscoe
Problems:
Any ideas?
Roscoe
- Cogita
- Oil Seal
Re: Karmann Ghia headlights problem
Here is a pic of the sealed beam headlights
- acpaterson
- Has thanked: 80 times
- Been thanked: 131 times
Hey Roscoe,
can you not see any print or stamp anywhere relating to their Voltage perhaps?
If you say they're very DIM when you're supplying them 12 Volts, then they can't be 6 Volt I don't think, or it might be their park elements on and the main elements are burnt. They might have already blown when you first switched them on unfortunately.
I'm sure with some careful dremel work they could be modified to allow fitting of a current nrmal headlight bulb, but it would require some careful cutting and grinding to make the hole and supporting clips and springs. I don't see any alternative then at this point of you say they are sealed beam. Or, you'd have to try break the seal around the headlight lense to get into the light to replace the elements, and then re-seal when done.
Good luck, it might be the best way for you to keep using them by doing this Roscoe.
regards
Alan
regards
Alan
- Cogita
- Oil Seal
Thanx so much for your advise Alan. We gonna look at them carefully tonight. We were also thinking about doing work to the back to allow the fitting of normal bulbs and brackets.
Will keep you posted
Regards
Roscoe
Regards
Roscoe
- acpaterson
All good buddy,
I'm certainly not an expert, but it's the way I'd tackle the job if the finished result is cosmetically what you're after, and looks the part, the for sure, try to make it work for you.
Good luck, and keep us updated.
- hitlers revenge
- Been thanked: 36 times
My Ghia does not have sealed beams.
- Cogita
- Oil Seal
Hi guys
Bad news
2) They are perhaps blown as pointed out by my buddy as we tested it, Main elements are burnt.
Are there any other alternative headlights that would work? any places in Cape town that sell aftermarket ones.
Please help
I only have one headlight in at the moment
Roscoe
Bad news
1) The headlights are in fact, not Ghia headlights (volvo,mini probably)hitlers revenge wrote:My Ghia does not have sealed beams.
Please help
Roscoe
Sourly the Golf 1 semi sealed will work fine there ?????
works on all other VW's
used them on the fastback and they work excellent.
- Cogita
- Oil Seal
- John Alves
- Has thanked: 3 times
- Been thanked: 48 times
I've got golf ones on my Ghia, work fine but glass is flat not curved
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
1968 1500 SP Beetle
- Bratjie
- What model do you have?: 74
- Facebook: https://www.facebook.com/juan.buter
- Been thanked: 5 times
What's it look like with flat lights? Any pic's?John Alves wrote:I've got golf ones on my Ghia, work fine but glass is flat not curved
Esté robusto, ser fuerte!!!!
73 Beetle project
73 Beetle project
- Cogita
- Oil Seal
The one on the left(drivers side) was a Golf light, sadly it cracked and when we removed the chrome ring it fell apart. So yes, it did the job.
- Cogita
- Oil Seal
Hey guys
Decided to take those lights back and got me new lenses and bulbs. They fit perfectly and wow what a difference. When I switch on brights its really BRIGHT lol.
I bought them at Dynamic Motor Spares, Rylands.
Lenses were 92bucks each
Bulbs were 129bucks for the set
Thanx for all your advice.
Regards
Roscoe
Regards
Roscoe
- acpaterson
........."...I can see clearly now the.."......... (sing to tune)Cogita wrote:.
.......got me new lenses and bulbs. They fit perfectly and wow what a difference. .......
Great, glade you fixed up.
