Hi
For both the splitty bus hand brake lever and the gear stick R 150.00
I have no idea whether there is a demand for the other bits or what they worth. Make me an offer
Beetle pop outs and SP manifold
- VW-rules
- What model do you have?: 1961 Bus
- Has thanked: 10 times
- Has thanked: 19 times
Re: Beetle pop outs and SP manifold
VW-rules wrote:Hi
I will take it
the gear lever do you have the bottom spring and the little plate under the gear lever aswell
- VW-rules
The gear stick spring is there but no plate, no knob, no base. The hand brake lever has the rod inside but no spring, no knob and the short round bar that the cables get attached to is also missing.Bugger wrote: I will take it
