2.1 wbx engine parts for sale
Get your parts here
Kaptein
Has thanked: 2 times
Post by Kaptein »
I bought this engine with the intention of rebuilding it over time but after I stripped it noticed the case has cracks in it.So I thought maybe someone on here might need some parts and I can recoup my money spent.
It was a DJ engine code
Crank with rods and front pully(Run bearing on no 4)
Cylinder heads(see it does have double valve springs)-sold
Feul injection manifold with injectors and throttle body
Distributor
Flywheel with worn clutch
Theres more stuff but only mentioned stuff that I think is usable
Ferdinand
Has thanked: 235 times
Re: 2.1 wbx engine parts for sale
How much for the distributor?
Gerhard Volksie Bfn
What model do you have?: various
Facebook: Volksiemuseum gerhard
Post by Gerhard Volksie Bfn »
Kaptein wrote:I bought this engine with the intention of rebuilding it over time but after I stripped it noticed the case has cracks in it.So I thought maybe someone on here might need some parts and I can recoup my money spent.
Distributor
Ferdinand
Give me a call I will direct you to the right person. 0832650254
