Smallest battery for beach buggy?
- Loopy
- Has thanked: 11 times
- Been thanked: 6 times
What is the smallest battery that will suffice for use in a beach buggy? There is no electrical components installed, so basically the battery only needs to provide starting power. Am looking at moving the battery to make space for a lowered rear seating area.
- hitlers revenge
- Been thanked: 36 times
Re: Smallest battery for beach buggy?
Normally a 619 but check the sizes of a 631 or 634
JonnoDub
- Oil Seal
- Has thanked: 13 times
- Been thanked: 9 times
Robert. Once the engine is running all electrics is run off the alternator / genny. Plus the battery also gets charged.
A small battery is great if the car fires straight away, but if you have one thats too small, you might have an issue if it takes 3 tries or 10-20 seconds to get the engine to take.
Your best bet might be multiple small batteries all wired in parallel.
- JamesD
- Been thanked: 20 times
What's your price range? I can suggest a 2kg battery that is the size of a motorbike battery for 5 grand...With the same stored energy as a conventional full sized 36 amp hour battery but more cranking amps. There are cheaper ones as well but I like the ultrabatt. Google shorai for another option
From fastest to slowest:
'75 SP 1600 with a few mods
