Single or Crew cab, that is the question........
Single or Double cab ???
1969 Double cab
11
85%
1970 Single cab
2
15%
Total votes: 13
Wyntand5900
What model do you have?: '64 Beetle
Facebook: https://www.facebook.com/1964Toktokkie/
Has thanked: 10 times
Been thanked: 4 times
Post by Wyntand5900 »
Hi all, I have a 1970 low light single cab that I am restoring. I recently bought a "doner" body to use mainly on the front. The body I bought is a 1969 double cab. I am planning to use the entire chassis and the front of the '69. The more I look at the double cab, the more I realise that it is in much better shape that the single cab. The double cab really only needs an engine and rear suspensions that I already have on the single cab....... I always wanted to own a single cab.
What should I be restoring………… the ’70 single cab or the ’69 crew cab?
Wynand
1964 Beetle
Stoffel die Beach Buggy
1969 Double Cab
1970 Single Cab
Re: Single or Crew cab, that is the question........
dont sacrifice a good bus to save a bad bus. Rather get another donor and save both :hangloose:
Remember, with the extra space of the crew cab you can lock shopping away out of site... good reason to get the missus to come along for a drive
dixtoy
Has thanked: 60 times
Been thanked: 37 times
Post by dixtoy »
Like Tony said save both, crew cab's especially low lights is becoming hard to find.
1959 Beetle (Lindor)
1975 Fleetline panel (Ouvrou)
1971 Westy (Gypsy)
Cyndi Kritzinger
Facebook: yes
Been thanked: 64 times
Post by Cyndi Kritzinger »
HI.
I CHOSE THE DOUBLE CAB BECAUSE AS TONY SAYS......, IT IS A MORE VERSATILE VEHICLE.
THE CAB IS CAVERNOUS IN COMPARISON WITH VIRTUALLY ALL THE MODERN VEHICLES AND CAN COMFORTABLY SEAT 5 ADULTS WITH ROOM TO SPARE.
THE BIN IS LARGER THAN A STD BAKKIE BY ABOUT A FOOT (30CM). IT MIGHT SEEM A SMALL AMOUNT BUT SEE WHAT A DIFFARENCE IT MAKES WHEN LOADING.
AS DIXON RIGHTLY SAID....., IT IS A BUS NOT SEEN MUCH ANYMORE AND HAS A LOT OF CHARACTER.
IF YOU CAN SAVE BOTH; GO FOR IT. YOU'LL NEED LONG POCKETS OR HAVE TO BE VERY PATIENT.
EITHER WAY I'LL BE INTERESTED TO SEE WHAT AND HOW YOU DECIDE.
GOOD LUCK.
MARK
Double cabs will always fetch higher prices and be in greater demand than single cabs.
Single cabs are nonetheless very useful vehicles. @TonyZ, you can also lock up your shopping and tools in the huge treasure chest under the load bed on a SC.
FYI, there are significant differences between a 69 and a 70, especially in the cab and front end.
For the 70 model year, VW triangulated the front ends of the longitudinal chassis rails. This meant changing the font beam and its mountings, as well as changing the layout of cab wiring, fuse box, pedals, etc. Every year of early bay production has a significant number of one-year-only parts, and not all are interchangeable.
I agree with Tony, if you can, restore them both.
