Carbs again
Carbs again
How easy is it to found Weber IDFs here in SA and from what price range do they start of at?
Does anybody here have any experience with using Mikuni Carburettors from a 'bike on a Vw engine?
Is it worthwhile trying to use mikunis, i'm sure that they must be cheap to get considering the number of japanese Bikes that were sold here?
I posted on STF, got no decent response
What size IDFs are you after?? A set of 36IDFs can cost up to around 2grand, If you want new IDFs, that'll set you back around 8grand, depending on exchange rates
- Been thanked: 98 times
I know nothing about motorcycles, but most run side draught carbs, you would idealy need carbs that are down draught to run on a aircooled motor, as space is limitted in the engine bay when it comes to making manifolds etc, just a point to remember.
nothing wrong with webers.... they are absolutely great and worth every cent IMO. Only step up is fuel injection
- hitlers revenge
- Been thanked: 36 times
Fuel injection on a Type 4 motor ('flat' configuration, like what you have in mind with your Fast Back) is relatively easy, with a complete donor system from a 2.1 wasserboxer - I've done it myself a few years ago.
Looking at al the 2.1-badged Microbus taxis running in Pretoria, with Toyota engines SOMEWHERE there should be quite a number of systems available? I'd say with some careful shopping and patience, you should be able to fit with the whole system for under R 2000. And it WORKS!!
- Watercool
- Been thanked: 6 times
Pine but when you say 2.1 Microbus' with Toyota engines, are that 4 cylinder engines, like we do the Subaru engine retro fit? I always thought that the Toyota 4 cyl is to a rough running (shaky) motor for a successful swap. I did try the Subby swap, not enough power, then went to a Ford V6, nice but not there yet. The bus was to tail heavy with that lot of iron hanging behind the rear wheels. Now I am in the middle of a V8 mid engine swap in my bus. Will see how I like it, I already got a supercharger in the garage if I feel I need a few more ponies. Time and money are always the big enemy here.
Does anyone have a list of all the parts that I should source from the Wasserboxer engine?Pine wrote:Fuel injection on a Type 4 motor ('flat' configuration, like what you have in mind with your Fast Back) is relatively easy, with a complete donor system from a 2.1 wasserboxer - I've done it myself a few years ago.
- eben
- Site Admin
- Been thanked: 54 times
I'm seriously thinking of Wasserboxer injection, it all boils down to price and availability, if a pair of Dell'Ortos or similar comes up, i might as well go for those...eben wrote:BTW the oettinger wbx engine would cost you 30K new about 6 years ago....
Dont forget the DLRA Dell'ortos.... They flow better than Weber of the same size and you do still find service kits etc... They also came on the Alfa's
