Hi all
Was wondering if there is anyone on forum that has a lowlight deluxe bay with steel sunroof?
Lowlight bay with factory fitted steel sunroof
- sean
- Has thanked: 63 times
- Been thanked: 227 times
Re: Lowlight bay with factory fitted steel sunroof
Eugene had one, or it used to be I think. I think he converted it to a Westfalia camper at some point. He is on the forum.Nixon75 wrote:Hi all
Nixon75
- What model do you have?: 74 s/c
- Has thanked: 2 times
- Been thanked: 5 times
Re: Lowlight bay with factory fitted speel sunroof
Thanks Sean
I think he sold it as a westfalia. Can't think that I'm the only one with one?!!
Nico
- Sambabus
- Short Block
- Has thanked: 39 times
- Been thanked: 14 times
Pine had an awesome Pea Green one on fuchs years ago......why do you ask?
- Been thanked: 322 times
The Deluxe Microbus was obviously the most expensive configuration of early baywindow, so would have sold fewer than Kombis or panel vans, but they're not exactly rare. The sunroof was an expensive option so was not often ordered, which makes sunroof models that much harder to find.
The deluxe was the only baywindow bus that could be ordered with a sunroof in SA. In Germany you could even order a sunroof on a panel van if you wanted.
