Duel Weber Setting instructions
Has thanked: 425 times
Been thanked: 543 times
Hi Guys,
Here is a sheet of how to set up duel carbs
If you follow the steps, you will come right, if you skip a few lines, you will not get it right.
Right click, save image to your computer, enlarge, print......Easy........ :D
Enjoy....
Here you go....
Have also placed it under "Advice" for others to find, maybe the green mods can make it a sticky.
alvetro
What model do you have?: 71 Karmann Ghia
Has thanked: 2 times
Re: Duel Weber Setting instructions
Post by alvetro »
Hi here's a link to the PDF if you can't make out the photo's
http://www.dellorto.co.uk/images/parts/ ... 20BELL.pdf
