Bay Window Scrapers\Beading install? procedure?
- acpaterson
- Has thanked: 80 times
- Been thanked: 131 times
Hi guys,
for the rebuilders out there, can the guys perhaps give me a procedure as to how to re-install the front window components, specifically, new Scrapers, Glass Channel and the outer beading? I have received my complete kits from Just Kampers, and would like to do this properly, ONCE..
Any help appreciated?
thank you.
Alan
thank you.
Alan
- Muderick
- Has thanked: 42 times
- Been thanked: 69 times
Re: Bay Window Scrapers\Beading install? procedure?
Thats one of the shittiest jobs on a bay bus.... one wrong drukkie and that ally trim is bust. Careful Alan!
http://www.ratwell.com/technical/CabDoor.html
1/4 vent http://www.ratwell.com/technical/CabDoor.html#vent
outer scraper: http://www.ratwell.com/technical/CabDoo ... terscraper
inner scraper: http://www.ratwell.com/technical/CabDoo ... nerscraper
Muds
Muds
Old School or Bust!
- acpaterson
Thanks Muds, that looks perfect.. I will mentally prepare to resolve this soon. that beading is so fragile, I can see it's an easy thing to screw up, thus my question..
cheers
cheers
- Muderick
Tip: I always find it easiest to 1st install the inside scraper and then the outer one...
No worries Alan!
No worries Alan!
Old School or Bust!
- acpaterson
Jaa, it's the sequence of what goes back. My quarters are fine, they not moving, so it's the rubber surround,t he felt channel, the inner, and the outer\beading.. In your opinion, best sequence?
- Muderick
Best is to go through the whole cab door overhaul by Richard Atwell...
Interesting fact: the VW dealerships presented master mechanics with a trophy in the shape of a vent window after completing their final and hardest certification exam. LOL!! I told you this may be the hardest thing you will do.
Muds...
Muds...
Old School or Bust!
- jolas
- Has thanked: 393 times
- Been thanked: 173 times
Take some pics as you go please Alan - same job for me coming up one of these days ...
- Drusky
- Has thanked: 77 times
- Been thanked: 15 times
Muds, those links are gold. Thank you so much!
Got anything on installing ally trim in Deluxe window rubbers?
- didi
- Has thanked: 9 times
- Been thanked: 37 times
Here's some comments from my restoration in 2012
And is it soft and does it work, is it local supply or import, will you fit mi......Sorry, got carried away...
[/quote]
LOL Herman, I’m getting good at this as this is the 2nd Kombi i'm replacing the outside window scrapers.
The 1st installation was a lot easier. I imported German quality from Busdepot in the US. It was a perfect fit and simply clipped in at the bottom. The beading was curved perfectly.
The 2nd order was from another supplier and a bit tricky. There were fewer clips to clip into the bottom of the door and the profile of the beading was not correct. I had to bend the beading to fit around the corners and had to shape the ends to fit into the frame. It is soft and easy to shape but flimsy.
My other mistake was that I didn't fit the window and window winder first. It cost me some time to strip and re-do. I hope this info helps.[/quote]
Must agree, looking good, nice and neat - is that window scraper installation a mission or pretty straight forward ?[/quote]retrovan wrote:well done SIR, looking good
[/quote]
_______
- Brandenmance
- What model do you have?: Bay window
- Been thanked: 3 times
Mud's those links are amazing. Wish I had them when I done mine. But it is a very easy job
Good luck Alan
Good luck Alan
- acpaterson
Branden, I expect to see you at my house Saturday Morning to "help"..
- Brandenmance
Lol early ish Mr. It.s the only day I get my lay in. But also might still be working.
