1978 Westfalia Helsinki
- What model do you have?: 1978
- Been thanked: 2 times
Here are some pics of my Helsinki,the interior is original and in great condition.
Green 78 Westfalia Helsinki,
2056 with 41 x 34 valves,ported heads
Fully balanced
8,5:1CR
JPM Custom made cam
JPM 7075 dual taper pushrods
IDF 40's with 28mm venturi's
Phyton CSP 42mm exhaust.
Accufire electronic ignition.
115HP (dyno)
Fully balanced
8,5:1CR
JPM Custom made cam
115HP (dyno)
Re: 1978 Westfalia Helsinki
interesting colours...
does the cooker move out of the way to allow you to walk through?
- jolas
- Has thanked: 393 times
- Been thanked: 173 times
Lovely
Is it still the original green colour on the outside ?
Yes,the cooker hinges up into the cupboard so you can walk through,the outside is a two tone green/white original colours.
It has been resprayed before i bought it but Its not the best sprayjob.Now that ive done the motor the next project is the rust and get a proper respray done in the original colours.
I will get the bumpers powder coated,all new door/window rubbers etc.
I have a new tent for the pop top.
Interior is amazingly scratch free but the carpet is a bit stained so i will be fitting wooden flooring and new Madmatz carpet up front.
I have fitted later style seats with headrests which will be recovered in the Westy plaid.
Before i fit all the interior parts in I will be doing sound proofing too and running new wires for speakers.
It has the Original plastic double glazed windows which are really good at stopping condensation.
It too has the Truma gas heater which is good for early/late summer camping.
Basically im going for a really no holds barred refurb.
It lives in my double garage which has under floor heating so it will be kept dry.
The thing im most looking at is polishing it when its been resprayed,im quite the mamba at polishing!
Fully balanced
8,5:1CR
JPM Custom made cam
115HP (dyno)
Fully balanced
8,5:1CR
JPM Custom made cam
115HP (dyno)
If you look at the second pic past the fridge you can see the cooker in its stored position,looks just like a cupboard.Its really clever.Tony Z wrote:interesting colours...
Fully balanced
8,5:1CR
JPM Custom made cam
115HP (dyno)
Fully balanced
8,5:1CR
JPM Custom made cam
115HP (dyno)
