A-Frame
Darth
What model do you have?: One with wheels
A-Frame
Post by Darth »
Anyone got an A-Frame that I can borrow for a day. Need to move TieFighter to its new home but got no a frame.
Pls PM me urgently.
Darth...
Do! Or Do Not! There is no Try! - Yoda
If I haven't offended you today yet, then wait you fcken turn I'm still getting to you.
Wake up each day to be a better you. Unless you are a DOOSE Don't be a better doose!
Darth
Re: A-Frame
Post by Darth »
Or a design for one to be made?
Re: A-Frame
there are designs on the forum somewhere... look back a few years
Re: A-Frame
I think Herman posted a design for one.
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Re: A-Frame
Post by buggyfan »
@Darth,A-frame as built by @retrovan
http://www.aircooledvwsa.co.za/viewtopi ... 8&start=30
buggyfan
Long Block
Re: A-Frame
Post by buggyfan »
@Darth,detailed drawings if you want to build your own a-frame
http://www.aircooledvwsa.co.za/viewtopi ... ans#p53106
Darth
Re: A-Frame
Post by Darth »
Thanks guys. Anyone given some thought to a hide away aframe? One that slides out when you need it. Cause really who are we fooling, The DarkSide had more km on the clock being towed than under its own power! A frames are like fan belts, points and oil; never leave home with out them.
I had some ideas but would like to know your thoughts...
Darth
Re: A-Frame
Post by Darth »
And would you say that the close to the wheels the aframe attaches, the easier it is to make sharp turns at parking lot speeds.
Re: A-Frame
Darth wrote:... at parking lot speeds.
In other words, at sub-warp speeds.
buggyfan
Long Block
Re: A-Frame
Post by buggyfan »
Darth wrote:Thanks guys. Anyone given some thought to a hide away aframe? One that slides out when you need it. Cause really who are we fooling, The DarkSide had more km on the clock being towed than under its own power! A frames are like fan belts, points and oil; never leave home with out them.
What you describe sounds like the towbar found on the MEyers tow,d
www.thesamba.com/vw/forum/viewtopic.php?p=7128256
buggyfan
Long Block
Re: A-Frame
Post by buggyfan »
buggyfan
Long Block
Re: A-Frame
Post by buggyfan »
