Hi guys, looking for links to any past threads or info on converting a bus from LHD to RHD, including adding a side door on the left.
Cheers
LHD conversions
- buggyfan
- Long Block
- Has thanked: 95 times
- Been thanked: 87 times
Re: LHD conversions
Heres how Coop tackled the lhd to rhd issue including adding a bit of stretch to his bus
http://themarigoldproject.blogspot.com/ ... 9.html?m=1
- Been thanked: 322 times
Re: LHD conversions
Haha, from your thread title I thought you wanted to convert a RHD bus to LHD! Search thesamba.com forums. I remember a thread by an aussie who did this and posted all the details
It is doable, but not a small job. The biggest job is moving the cargo doors to the opposite side. IMO, you'd do better to leave the cargo doors on the RHS and add cargo doors on the LHS, to give you cargo doors on both sides. Then you need a RHD dash (I have one for you), a RHD steering box (hard to find), RHD pedal cluster and possibly a RHD pitman arm (not sure about that). If you want to do it right, you would also need RHD cab floor panels.
Things like brake lines and control cables would also need to be changed and repositioned. You would also need to swap the front seats and mountings around.
- What model do you have?: 74 bay truck
- Has thanked: 9 times
Re: LHD conversions
buggyfan wrote:Heres how Coop tackled the lhd to rhd issue including adding a bit of stretch to his bus
Thanks, I wish I had a RHD drive just laying around to cut up.
"Is the juice worth the squeeze?"
Re: LHD conversions
Thanks fig, I was heading along the lines of adding the side door too.
I read that there are peddle conversion kits too.
I'll search samba,
Thanks bud
I'll search samba,
Thanks bud
- Derek
- Been thanked: 25 times
Re: LHD conversions
Lots of work, but can be done. I'm leaving my LHD '91 Westy as is for the moment as it's not that difficult to drive on our roads...
'70 Dormobile - 1.6
'76 Brasilia - 1.6
'76 Brasilia - 1.6
- RikusVisser
- What model do you have?: 1969 T2 Westfalia
- Has thanked: 12 times
Re: LHD conversions
Leave it as is. Love my LHD westy. Its something different and a great conversation point.
I do understand that you are renting yours out but if your client got their license the honest way it is not a problem. Takes 5min getting used to.
