R2500
Thanks for the info, much appreciated.fourier wrote: Fri Aug 03, 2018 12:15 am Jack, just be sure that you get the correct windscreen for your car.
Beware of the confusing information in this thread. Pre-'66 cars with the C-channel chrome trim around the windscreen, will take a larger 17,25" (height measured in the centre) windscreen, and post-'66 cars with the aluminum T-profile trim, take the 17" screen.
The physical windscreen openings are identical for both cars, but the smaller screen was used in post-'66 models, to accommodate the T-profile aluminum trim. You could technically fit the smaller screen to your car, provided that you also use the later T-profile trim and matching rubber, but that would not be period correct.
Let me know if you find a 17,25" windscreen locally, as I have only seen the later 17" windscreens advertised.
