My Daughters ride
mcg
What model do you have?: 69 vw beetle
My Daughters ride
Post by mcg »
In the process of breakdown to rebuild
Re: My Daughters ride
Good luck with the project, keep us posted. We like seeing other peoples progress.
mcg
Post by mcg »
Small update pulled engine and all wiring and windows.
Chelsey took all the fenders off herself and removed the old floor seals to reveal a almost new pan
mcg
Post by mcg »
Motor still seems in good nik just need to clean her up gearbox rear seal finished
going to rebuild the gearbox.
much more moola to spend.
mcg
Post by mcg »
Storage is a problem
nice progress
you doing a full re-wire or installing the old loom back again?
Looks like a really solid Beetle as it is, nice score, keep the pics coming - ja, storage is always an issue ....
mcg
Post by mcg »
Tony Z wrote:nice progress
Hi Tony going to do a full rewire
mcg
Post by mcg »
A busy weekend high pressured the whole car got most of the
old junk off.
started inside the vehicle removed headlining and every thing else we could
going to use Abe waterprrofing ali sealer for firewalls floors etc.
Front disc kit should be here this week sometime.
Now to remove front end and gearbox
will update with progress.
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
Its good to see the castle can in place so you can keep a eye on things. Good luck with the build.
What area are you in.
car cleaned up nicely, good condition body you have there.
Best of luck with the build, can not wait to see it completed.
Thanks for sharing
62RestCal
What model do you have?: 62
Post by 62RestCal »
Terry Phillips wrote:Its good to see the castle can in place so you can keep a eye on things. Good luck with the build.
Its called a "liquid wrench" Image
lowlight
Post by lowlight »
Probably South coast
mcg
Post by mcg »
Sorry Terry yip south coast Port Shepstone
JC Rousseau
What model do you have?: 69,75split,75,79scab
Has thanked: 85 times
Been thanked: 16 times
Post by JC Rousseau »
That beer is still closed why????
Nice body still looks good, is that the og paint?
61 Beetle aka klapperkiste
68 Squareback viewtopic.php?f=23&t=34408
69 Kombi
72 Crew cab viewtopic.php?f=23&t=32846&hilit=1972+custom
75 Fleetline panel viewtopic.php?f=23&t=32485&p=309053#p309053
79 Single cab
