that is the trim plate, what tells you what was in your car,..........BUT.....
VWSA had fires and bad record control, so no one can tell you what it means.
Me thinks.....
best you can do is find a place under the dash or behind a panel, that has the original colour, and have it matched.
Even if you had the code, you may still not know what colour that code represented.
There is a thread on ACVW but not complete.
