Renovated 1971 kombi engine
Get your parts here
hendriks
Been thanked: 13 times
Post by hendriks »
1971 1600 twin port engine newly re-done
The engine has bern in storage for a few months. Only bench run. Not fitted since referb.
I have a list of work done on it. Including porting of inlet and outlet valves
Balancing of flywheel and so on
Tinware sand blasted and sprayed black again
Engine hanger invluded
Carb refurbed as well(standard carb)
Only needs a new exhaust then its "plug and play". I have an exhaust that can be used but ideally a new one would compliment this engine.
Inhad the engine build but dont have a kombi currently
For pics watsapp me
R9500
Hendrik
0764two47815
james309
What model do you have?: Crew Cab
Post by james309 »
Where are you Hendrik ?
