Before
I ripped out the dashboard, mainly to fix some electricl issues, and replace the steering wheel with something less, uhm, ugly. It is still a work in progress, should hopefully finish is soon. The wood is now replaced with brushed alluminium - was harder than I thought, but fun. I didn't budget on the speedo cable, wich is stiffer that I thought. It may present itself to be a problem.
Almost Done
It also looks a bit stupid inside the car, I think it is because it comes down quite low, but not sure though. Interstingly (or not) I have used aircraft ally to make the dashboard, and had absolutely no help - hence the rivits and scew lines
There was a little bit of elbow grease involved too!
Before
After
All this is is just a bit of paint on the gear lever, handbrake, and steering column. Luckily it was surface rust on the pan, so I took that off - and went over with a tin of rubberizing paint.
OH Yes, there was violence.
This WAS the little hub/part thing that keeps the gear knob attached to the lever. Unfortunately it had to go too.
I hope you enjoyed this, and I will try to keep updates as, and when I can. This little bit took me almost 4 months, mainly because I have to get things done when I am alone.
