Bloodhound LFB golf to Rotary
This Beetle was at 2014 Desert Speedweek Hakskeen pan and did a GPS 215Km/h and I missed the Traps as the track was turned around and I did not understuud the marchals inital instructions
Bu then the run straight After that I managed to do a official 206Km/h with a Warm motor and intercooler
It was a serious challange to do this Speed 215Km/h in a Beetle but then on Sand it was even hiher risk as the Track
was Quite ridden out by the time we arrived at Speedweek
I had a 2L 8Valve Turbo Charged Golf Motor in Bloedhond that made a around 145Kw on the Wheels at the time
Gearbox is one of my Bugger Stage 4 Transmissions with chrome molly main shaft with longer 1st and 2nd gears
as well as Coarse 3de and 4th with a super long 4th gear Ratio of 0.82 where standard is 0.93 and my first longer ratio
I normally do have a 0.88 in same as Tony Z stage 4 Box then welded 3de and 4th gear hube
Super diff housin with 4 spider gears and both sides of the Box have HD ally Side covers
steel Selector Forks and Special Imported Syncro rings on 2nd 3de and 4th
With that I also used a set of Chrome Molly Side shafts to handel the Power
I have had engine Failure when the Guys were tunning the motor for some more power on the Dyno and removed the Golf motor and started with the 13B rotary Turbo conversion with a Charge cooler system and Bridge ported and hybrid small turbo to bring power in at low rpm
One of the Reasons I have gone to the Rotary route is the 9000-11000 RMP of the Rotary and seeing this bug is built specifically fot Speedweek on the Hakskeen Pan and All Tar
aswell as to do the 800 and 1Km challanges at ODI the aditional RPM i will be having will only help with top speed
My aim is to try and break a 250Km/h speed with the new Bloodhound LFB project and that will be my challange
Will post pics
Will post pics
Re: Bloodhound LFB golf to Rotary
It was looking brilliant last time I was there.
Good work as normal there Pierre
Please post some pic's, as it will be an inspiration to a lot of guys here on the forum.
You will see the heading is called
Bloodhound LFB.
The bug have been renamed after
Bloodhound SSC ( super sonic car)
Now you ask why change the name to Bloodhound LFB
LFB stand for Low Flying Beetle.
What is life without humor
Thanks Uncleretrovan wrote:It was looking brilliant last time I was there.
https://vimeo.com/202661232
Just a short video clip
Busy getting Hydralic clutch master and slave conversion
https://vimeo.com/202661608
Short video clip of Dyno run with Chilli Pip
13b rotary turbo
13b rotary turbo
https://vimeo.com/202662016
Video of Chilli Pip dishing out a Hiding
What you guys think of this Launch out of the Hole
Chilli Pip have been Retired and Sold on to a mate doing a Roof chop on the Body
A video on Fb. At this stage viewed 82400
In 4 days
More than 150000 views
Rhino Transmission casing upgrade
2 x custom Steel side covers and
2 x steel brace plates to try and keep the Diff inside
Busy welding 16mm steel bracing on the Frame Horns to help them from bending when Launching
Gave the transmission some color and the Firewall of Bloodhound LFB
Nearly time to start assembly and neatening everything
First pic bottom of transmission installed the Yankie style Through bolt to assist in keeping the diff inside the housing
2nd pic made a brace over the Bellhousing to strap down and braced the bottom solid mounting
3de pic you can see the rear brace pulling box down
And with the Rollcage passing shock tower to shock tower I took the Advantage to make 2 braces bolting to the transmission HD side plates to help eliminate any possible transmission movement
