Ok
Guys let’s see or hear of your Bush Repair to get you home
Some of them have done/Repaired after getting home
And Some still running without a change
https://youtu.be/S9_OzmJ6CHY
Bush mechanics Repairs
Re: Bush mechanics Repairs
Here are Buggers 3 videos
- Eugene
- Has thanked: 59 times
- Been thanked: 65 times
Gotta love the Soutie's Afrikaans
and Sean standing by with angle grinder
Come guys let's hear your stories of doing a Bush repair getting you home
Terry Phillips
- Has thanked: 193 times
- Been thanked: 121 times
Mazda 323 clutch cable bracket under the dash broke used vice grips to hold the bracket to under the dash. That was like that for years then they stole it.
The other one was a truck I had to get back to town and the driver wondered off the road and the diff with a mild steel sump ended up with a hole in it and the diff oil drained out. I took oil but could not do much. Then the driver took out his sunlite soap the green one and he shaved the soap made it into a paste with a bit of water stuck it on then smothed it out with a bit of water and stayed like that like that for about a week.
Then same thing radiator was leaking water stuck the soap to the hole again it ran for months no problems.
Thanks for Sharing
Let's wait for more stories from yester years
