67 Beetle Fuel Pump Replacement
Rowan
What model do you have?: 1967 Beetle
Post by Rowan »
Hey guys
So the time has come for me to replace my fuel pump. The guy at my local Goldwagen recommended the fuel pump in the pictures attached. Also attached is a pic of the pump that needs replacing. Just need some advice on whether the replacement fuel pump will be appropriate?
" Don't gain the world and lose your soul...Wisdom is better than silver or gold " - Bob Marley
Has thanked: 45 times
Been thanked: 208 times
Re: 67 Beetle Fuel Pump Replacement
No.
Is your existing fuel pump faulty? Looks like the circlip became unstuck and the little shaft slided out. Maybe fixable?
I see an alternator and matching angled late model fuel pump in your top picture. Late pump is angled to provide more clearance next to the alternator. It also uses a different length operating rod.
Bottom picture shows what looks like an early non-angled pump. Which would have worked if you still had the original generator setup.
Rowan
Post by Rowan »
Existing fuel pump is faulty as per my knowledge ( which is somewhat limited ).....engine swings, coil is good, points are good, just not starting. Please could you shed a little more light on the "circlip becoming unstuck" and i did notice that little shaft on the side of the fuel pump thats no longer there. Is it possible to just get a replacement shaft and slide it in? Please excuse my ignorance.
Merlin
Has thanked: 20 times
Been thanked: 39 times
Post by Merlin »
The shaft contains and controls the lever which pushes the diaphragm. No shaft, no pumping.
Depending on the style of the pump, you can sometimes run a genny pump with an alternator setup, with minor clearance. You may need to swap the rod out.
The problem you've experienced is common. The shafts should always be peened against the housing.
Rowan
Post by Rowan »
Noted, thanks for the assistance. I did do some research and noticed that the rods are specific to the fuel pumps
Near the pump's 13mm mounting nut you see a little hole. That is where part of the shaft should protrude, with someting preventing it from sliding inwards. Feel on the other side of pump if shaft has pushed through.
Rowan
Post by Rowan »
Hey Guys
So ive just changed the fuel pump with the correct one ( see pic attached ) and the engine does the same thing it did before the new pump. Just swings and swings. Not starting at all. Am i doing something wrong?
Are your pipes connected correctly. Which pipe is "in feed" and which pipe feeds carb?
Rowan
Post by Rowan »
Pipes connected as per the old pump. In feed is connected on the top inlet of the pump and carb pipe at the bottom inlet of the new pump
To test, loosen fuel pipe at carb. Hold pipe over some container to catch fuel. Remove wire from points at coil to disable spark.
Turn key if you have someone available to assist.
Otherwise, (what i do):
Loosen the two 13mm fuel pump nuts. Put in neutral and turn engine untill fuel pump's operating rod pushes the pump upwards to its highest point and stop turning when rod start moving down again.
Now manually push pump down and up, (which will work the lever to operate pump). Fuel should exit into container.
Alternatively one could remove pump from studs and simply operate lever by hand, while still connected to pipes.
This is also a good way to prime the carb's floatbowl if empty.
Rowan
Post by Rowan »
Dawie wrote: Sat Aug 04, 2018 3:28 pm To test, loosen fuel pipe at carb. Hold pipe over some container to catch fuel. Remove wire from points at coil to disable spark.
I will try that and let you know what happens. Thanks appreciate the advice.
You will need to bleed the pump, to get the air out.
Suck on the carb side pipe with a long hose till the fuel comes through.
With air in the pump, it will not work.
Been thanked: 100 times
retrovan wrote: Mon Aug 06, 2018 10:18 am Suck on the carb side pipe with a long hose till the fuel comes through.
I once saw a guy take a good mouthful of petrol doing this, so I wouldn't do this. If you fill the float bowl manually via the top of the carb, there would be enough fuel for the engine to run while the air in the system is bled through the carb.
73type2 wrote: Mon Aug 06, 2018 12:45 pm
Opens the sinuses,no big deal, have had that happen a lot, that's why I said long pipe......
With a dry new pump, it sometimes will not bleed by running the engine, and needs to be internal wet 1st.
Rowan
Post by Rowan »
Havent got a chance to get to the issue yet but thanks for the advice guys. I will try to get some fuel in the carb first before i try sucking on the carb pipe haha
