One of the twins got their license so I need to get a move on
Had a leaky carb and the arms were so worn that it needed to be replaced
Thanks to Mark and his Milo tin I managed to get a much better Solex 34 pict 3 in there with a new kit
Guess what the carb is still leaking a drip every now and then.
Replaced tubes but still leaking
New carb kit in still leaking
Leaking ends up on the accelerator cable end and drops exactly on the points electrical connection on the distributor.
This can be catastrophic.
My driveway is at a slight angle and was wondering if this could be the cause of the problem.
I have not checked parking it level of the problem persists since she is not driving at the moment I cannot move her and there are a few cars behind her that needs to be moved which is also not driving so that will be a Saturday project just to get her out of there.
My question here is has anybody else had the problem with the beetle standing at an angle and having that leak ? Or is there something else I need to check?
BEE also has a Golf electronic ignition system in there which I have found out the curve is not 100% and she has a poep or two when she gets into the higher refs
Have managed to get a newish dizzy in there one that was used for a week apparently bought originally from Volkspares
Will run it for now on points and condenser just to have her running and will keep a couple of extra sets just in case.
Money is not permitting an electronic ignition upgrade at the moment.
[emoji1221]
