How to confirm production year from engine number or vin code
dws1976
Has thanked: 2 times
Post by dws1976 »
Hi
I'm new to the forum and want to know if item is possible to confirm year of manufacture from a VIN code starting with AAPV?
Engine code starts with ADTR
David
Re: How to confirm production year from engine number or vin code
AAPV numbers are stamped when the vehicle is stolen and recovered or if built up and no VIN number exists etc No way from dating based on that
Maybe post some pictures of the actual vehicle and can identify based on features found on model year
dws1976
Post by dws1976 »
Hi Thanks for quick reply. It's an RSK kit car so unfortunately I don't think pictures will help.
When one registers to build motor vehicles in South Africa, you get issues 2 sets of 3 numbers from the dept. of transport.
The manufacture then registers the in between 6 numbers to make up the 17 number Vin code.
If you have a builders number on your car, which if you go or contact the dept of transport, will tell you who made it when it was made, where in SA it was made, what it was when made and also which number it was on the production line.
When a stolen car was recovered and the numbers filed off, you got Cop numbers to get it back on the road, also if modifications or home built cars also got there numbers.
PS, the cops only use AAP on chassis and not sure which they used on engines numbers, all others are builders.
