Mid Engined Change over Gearlever system info needed.
Has thanked: 151 times
Been thanked: 377 times
Flag: Netherlands
Post by retrovan » Fri Oct 12, 2018 4:56 pm
Hi Guys
Anyone have the drawings for gear-lever mechanism changes to bring the gear-lever from the gearbox side to the engine side.
In other words, need to change the gear lever to mid engine format.
So the sequence will be Gear-lever - Motor - Gearbox.
Thanks in advance
1952 Split Beetle 1835cc (Azure Blue)
1968 Fastback 2Lt.type4( Red)
1972 Low Light Bay Panel Van 2Lt type 4(White)
1975 Fleetline Panel Van 1914cc (Aqua Blue/White)
2019 MeFusco Beetle Truck
Has thanked: 368 times
Been thanked: 168 times
Flag: South Africa
Re: Mid Engined Change over Gearlever system info needed.
Post by jolas » Fri Oct 12, 2018 7:37 pm
What on earth are you up to now captain ?????
buggyfan
Long Block
Has thanked: 74 times
Been thanked: 72 times
Flag: South Africa
Post by buggyfan » Fri Oct 12, 2018 7:43 pm
So basically you need the setup of the gearlever as found on a formula Vee racecar or a Rsk porsche kitcar with a midmount engine
buggyfan
Long Block
Flag: South Africa
Post by buggyfan » Fri Oct 12, 2018 7:46 pm
Been thanked: 23 times
Flag: South Africa
Post by Haans » Sat Oct 13, 2018 10:07 am
You've gotmy attention Herman!
What are you up to ?
Flag: South Africa
Post by Haans » Sat Oct 13, 2018 10:11 am
Imagegot this a while ago,,.....think its what you arelooking for
Flag: Netherlands
Post by retrovan » Sat Oct 13, 2018 10:22 am
Thanks for your link, Yes that what I want to do......... :roll:
Thanks Haans
You've got my attention Herman!
YES ...I'M Back..... :shock:
Piet
What model do you have?: type 3, Porsche 550
Been thanked: 15 times
Flag: South Africa
Post by Piet » Sat Oct 13, 2018 1:13 pm
Here is perhaps a clearer image. It is a drawing of the original Porsche Spyder/Rsr mechanism. I'm in the process to reproduce it for authenticity sake, but there are easier ways to accomplish the sameImage
Piet
Piet
Flag: South Africa
Post by Piet » Wed Oct 17, 2018 5:04 pm
The real thingImageImage
Piet
Flag: South Africa
Post by Haans » Fri Nov 09, 2018 8:43 am
So !,.......is there a "sneak preview ". Available yet ?
Its too quiet to my likiing !
Haans🤔
Flag: Netherlands
Post by retrovan » Fri Nov 09, 2018 10:11 am
No, Haans, This can not be done... :roll:
What I can tell you is that I have collected the following;-
Rusty Beetle Body (road side display saved)
A type 4 2lt motor in sorry state
Type 4 Gearbox in unknown state
4 Pro-white rims with 195x 80R / 14 C tyres
Renault Scenic Back axle assembly with disk brakes
Opel McPherson struts with disk brakes
Opel steering rack
Corsa Power steering wheel assembly complete
Rusty split bus rear corner units
Lots of Laser cut steel sections.
and an overhead gantry with chain block.
And .... :shock:
Well you have to wait... :wink:
64 Notchback
What model do you have?: T3 DC, RSK 718 proje
Has thanked: 75 times
Been thanked: 35 times
Flag: South Africa
Post by 64 Notchback » Fri Nov 09, 2018 10:23 am
To quote a line from The Rocky Horror Picture Show.
" I see you shiver with Antici.......pation" :):):)
Flag: South Africa
Post by Haans » Sat Nov 10, 2018 1:20 pm
Ok,... I'll try andhold out.
The list is confusing,......and surprising
Has thanked: 136 times
Flag: South Africa
Post by Tony Z » Sat Nov 10, 2018 2:00 pm
looking at the list, my guess is one of two things...
race car of sorts - but I think that is beyond his age bracket :flash: and he isnt going to use pro-whites on a track
so it is likely a rock crawler of sorts so he can easily cruise over Sani Pass next time.
my guesses anyway
Flag: Netherlands
Post by retrovan » Sat Nov 10, 2018 7:06 pm
Haha I like the way you guys think.
:shock:
But no!
