hoover plate
Vintage man
Has thanked: 51 times
Been thanked: 7 times
hoover plate
Post by Vintage man »
Hi All
How important is the hoover plate and is it safe without one.Got 1600 in my t2.
Vintage man
Re: hoover plate
Has anyone got this hoover plate for me.
sean
Has thanked: 63 times
Been thanked: 227 times
Re: hoover plate
Post by sean »
This is very important. Commonly left out by lazy engine rebuilders.
fourier
Has thanked: 31 times
Been thanked: 37 times
Re: hoover plate
Post by fourier »
Air will bypass the oil cooler, so don't run without it. It is like every other piece of engine tin on an aircooled VW... important to ensure proper cooling.
(o= i =o) (o\ ! /o)
Camshaft
Been thanked: 107 times
Re: hoover plate
Post by Haans »
You've got interest !! What does a "hoover plate" look like ??
Please
Re: hoover plate
Haans wrote: Tue Dec 04, 2018 9:23 am You've got interest !! What does a "hoover plate" look like ??
Please
To be found on your oil cooler.
Camshaft
Re: hoover plate
Post by Haans »
Thanks Herman,....never seen it before !!😱
Will keep an open mind when fiddling in that area again,....and when scouring in scrap yards !!
Never ever seen it !
Vintage man
Re: hoover plate
Silly question ,if not fitted and motor is in can you seal that area externally with dynamat
Re: hoover plate
I normally fill tin holes with aluminum duct tape, and spray it black.
That should work till the engine comes out at a later stage.
Re: hoover plate
retrovan wrote: Tue Dec 04, 2018 11:31 am I normally fill tin holes with aluminum duct tape, and spray it black.
I also replace the narrow strip of foam that goes over the oil cooler with thicker foam the full width of the cooler, which helps seal some of the gaps covered by the "Hoover bit".
The "Hoover bit" is hard to find and most of the ones I've found were cracked. Because the fanhousing screws onto it, I think many of them were damaged when people forced the fanhousing when it was still screwed to the Hoover bit.
FYI, since I know some people are asking by now, this part is called the "Hoover bit" from the Sermons of Bob Hoover, a series of mechanical lessons for ACVW mechanics written by the late Bob Hoover, who was one of the first people to note the importance of this tiny (usually missing) part.
Re: hoover plate
If anyone is interested, I have a few new hoover bits as well as a few pairs of the lower tin (rear plate that goes below the cylinder covers) that I am happy to part with.
