Carb Settings on Solex 31-pict3
Jlou
What model do you have?: 1979 Beetle
Post by Jlou »
I have finally reached the next step and found out I am very close to noob level on carbs.
I am currently running a Solex 31 PICT -3 on a 1500 sp- I have scoured the internet, and found very little on setting the carb - most hits comes back on the Solex 34 Pict -3. As far as I understand the 31 is more "reliable" than the 34.
The question I have is 2 part
1) What is the correct setting for the volume control and airflow?
2) I suspect the sales person gave me a carb kit for a 34 -but I won't know the difference until its too late. Any advise on what to check for? Should it be the case can I still use the parts without any serious issues?
I am sorry to ask such a stupid question. :oops:
slak
Has thanked: 7 times
Been thanked: 32 times
Re: Carb Settings on Solex 31-pict3
Post by slak »
https://www.youtube.com/watch?v=8iF5sewX6UU
Follow these instructions the 34 and 31 carbs are very similar when it comes to settings
U Only Live Once Right !!!
Jlou
Post by Jlou »
Thank you for that. Really helps alot!
Been thanked: 100 times
Generally, Beetle carb kits aim to cover a range of carbs, so you should be OK.
