182 Thing Project 1970 RHD
Madbones
What model do you have?: 182 Thing
Has thanked: 12 times
Post by Madbones »
Greetings,
Decided to start a new thread. With all the new projects on the go I thought it appropriate to get mine started. The rebuild that is, stripping it down was the easy fun bit. Now excited to get started on what is a very vrot 182 but a 182 none the less. So my current list of things to tackle:-
1)The pan was very rotten and was a fiberglassed bath tub mess. Cut out and sending chassis for sand blasting. Then install new pans.
2)The body itself is also quite bad with the usual rust in all the bottom parts where body meets chassis. Still deciding how to strip and fix this.
3)Had the front beam sand blasted and about to install adjusters. Have all new thing only ball joints ready to be pressed in.
4)New brake drums ordered and all new braking components needed as everything is original and very tired. No compromise here.
5)Trying out urethane bushes in the front beam as needle bearings for this and internal bushing rocking horse shit. Originals tired.
6)The list goes on............
Buged
What model do you have?: 1600 S & Oval
Re: 182 Thing Project 1970 RHD
Post by Buged »
Awesome project man!
Good luck ahead! 😃
...low n slow...
Very enthusiastic, can not wait to see next installment.
Someone as brave as me taking on a job normally avoided by most.
Good Luck
Madbones
Post by Madbones »
Thanks Guys.
Ja Herman you have sparked the fire under my butt to jump in. Not right for you to have all the fun.
Its going to be challenging for me but it starts with the first cut and one has to be bold :?
With some guidance and advice from the forum I see nothing but blue skies ahead :D
Till the next post then.
Ciao
splitfan
Has thanked: 46 times
Been thanked: 26 times
Post by splitfan »
Good luck man , a mate is also busy with one but he's is almost ready for paint so a little further along than you , parts on these are hens teeth locally
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
Nice one Richard hope it goes smoothly and you get lots of enjoyment doing it.
Madbones
Post by Madbones »
So I've had a lot of stuff sandblasted and very pleased with the results. Removed old pans or what was left of them and ready to weld in the pans.
My mate has a kitted warehouse with two post lift so Ive finally found heaven. Have all new parts ready to start bolting on.
Just makes live so much easier what a pleasure. So now the "put everything back together" begins. Still a long way to go but I think ive picked the easiest car to restore, I might regret those words :cry: . Having said that the body is going to be a mammouth task and scared to see whats under the green paint. Plan is to work on it every Saturday what with work and children :wink:
Ciao
Madbones
The commitment is the hardest part, the work just follows on.
Great work, and good luck with your build.
AND REMEMBER its YOUR build.
Camshaft
Been thanked: 107 times
Post by Haans »
What a pleasure it must be to use a lift !!!,.......now is where courage keeps yougoing!!
Keep it up
Is that the same one I A-framed with my Fastback, from George to PE, some years ago. ??
Must look at my Photo's.
Madbones
Post by Madbones »
The very same one it a lot of pieces and minus the spade and axe. LOL
Madbones
Post by Madbones »
By the way do you know any history of this 182?
Madbones wrote: Wed Mar 13, 2019 1:29 pm By the way do you know any history of this 182?
PM sent
Jdt1976
Has thanked: 116 times
Been thanked: 90 times
Post by Jdt1976 »
Did you import most parts and what is the quality like?
Been thanked: 100 times
retrovan wrote: Wed Mar 13, 2019 9:10 am Is that the same one I A-framed with my Fastback, from George to PE, some years ago. ??
I don't see the A-frame Herman. It looks like you're just parking in front of the Thing, in the middle of the road! :D
