Ports on Type 2 twin carb headers?
mhsmuts
Been thanked: 4 times
Post by mhsmuts »
Hi guys, what is the purpose of the port/tube on the twin carb headers of my type 2/4 motor?Image
Sent from my SM-G950F using Tapatalk
Re: Ports on Type 2 twin carb headers?
if I'm not mistaken, those are connect from one manifold to the other with a decent sized hose. It helps the engine to drive and idel smoother by balancing the pressure pulses.
mhsmuts
Post by mhsmuts »
Tony Z wrote:if I'm not mistaken, those are connect from one manifold to the other with a decent sized hose. It helps the engine to drive and idel smoother by balancing the pressure pulses.
That makes perfect sense. It could balance the intake vacuum pressure
Perfectly correct, this stops the fuel from stop / starting in the manifold, giving a buffeting effect.
When the fuel flows then has to stop, and then start flowing again.
Makes balancing the carbs much easier as well .
Means your car runs smoother.
mhsmuts
Post by mhsmuts »
Thanks all
