Splitty Front Wheel Bearing Part Number
- Donovan D
- Has thanked: 148 times
- Been thanked: 73 times
Does anyone have the part number for this ?
Re: Splitty Front Wheel Bearing Part Number
take yours off and take them to GHS and ask them. They have cheap brands and good brands, ask for SKF, NSK, FAG or similar.
- Donovan D
Mine are fine, dont really want to take it apart to carry around as a sample.Tony Z wrote: Thu Jul 04, 2019 12:17 pm take yours off and take them to GHS and ask them. They have cheap brands and good brands, ask for SKF, NSK, FAG or similar.
Just looking for extras to keep in the kombi as spare. Was hoping someone wrote the numbers down somewhere as quick reference.
- sean
- Has thanked: 63 times
- Been thanked: 227 times
These are the Timken part numbers. Only buy from Westcape Bearings in Brackenfell. I've seen all kinds of Chinese things around, but Westcape bearings only sells the Timken USA ones.
Outer - LM11949 - LM11910
Inner - LM67048 - LM67010
This is for later model splits and all bay windows.
- Donovan D
Thanks Seansean wrote: Thu Jul 04, 2019 1:01 pm These are the Timken part numbers. Only buy from Westcape Bearings in Brackenfell. I've seen all kinds of Chinese things around, but Westcape bearings only sells the Timken USA ones.
If you go to (BearingMann) BMG they have a full kit that has all the seals and gaskets or lock washers in them.
It is still listed in their book
