Some Good news
As some of you might Know Vdubtech have Bought our own Line boring Machine
We Must Thank IMPI for his Assistance and Training with the line boring machine
We are busy setting up the machine shop and will be able to help our Fellow Enthusiasts to get the Job Done RIght
We do have the Ability to skim the Casings and Re size to Previous size or following size up
Brass gears clearance will be machined to fit
We Prefer to do the Line bore with supply M/Bearings and Cut the Crank then Bearing clearances can be sorted
Pls Fire away with any Questiones regarding the Machining side of Things
Pierre 0826008663
Vdubtech Eng
www.lineboringeng.co.za
1 Richdale rd cnr Shamrock
Primrose
Germiston
I will post some Pics as we do Machining for you guys to see.
