Baywindow Seatbelt upgrade
- Eugene
- Has thanked: 59 times
- Been thanked: 65 times
Hi all, I am looking to upgrade the Bay's seatbelts to inertia reel belts. I bought the Chinese version from local parts shop but lo and behold, they are too short! I cannot find any from Goldwagen. Any suggestions?
Re: Baywindow Seatbelt upgrade
Some guys buy Nissan Bakkie belts from the scrap yard, its supposed to fit.
I bought the same sets from Midas, but has extensions made for the side of seat buckles from my local cable guy.
Now I do not have to bend so low to clip my belt.
- Been thanked: 322 times
I bought the Midas ones and they fit my baywindows perfectly. The stalks are too short to mount in a split bus though. The belts themselves are long enough.
Forgot to tell you that they sell two models.
On the box you will see they have short stalks and they have long stalks.
You may have the short, then you just need to take them back and swap them.
Thunder bunny
- What model do you have?: T2 Kombi
I also bought Midas ones and then got T3 stalks. They work perfectly.
- Eugene
Thanks guys.....I will try Midas. The ones I returned, had the long stalks but was easily 500mm too short.
- Eugene
I went to Midas today and was surprised to find the very same ones sold at Good Hope....they are too short
- sean
- Has thanked: 63 times
- Been thanked: 227 times
Perhaps the occupant is too large for the seat belt???Eugene wrote: Mon Jan 13, 2020 3:37 pm I went to Midas today and was surprised to find the very same ones sold at Good Hope....they are too short![]()
- Eugene
That was nasty
with the seat belt fitted and no occupant to obstruct, the belt just reaches. They do come with a stalk as long as the box.
- freddiebooysen
- Been thanked: 47 times
Eugene. Are those the ones that roll out of the little roller
So if there is no occupant you need to roll a bit out of the roller
A simple pull should do the trick not too hard though else it locks
Have you got a bench seat or a through way with two seats ??
May be using the incorrect fixing points.
Mine is a walk through and I will take photos of the belts and fixing points is you want.
Here are my Midas Seat belts in My Bay
This setup fits me, ...and I am twice the man my wife married.
Hope it helps
Hope it helps
