Can someone pls measure the height of the running board mounting area on the beetle heater channels as per pic I need to get some steel strips cut to repair my donor heater channels the baja is not stored at my place so cannot measure
Thought I could help, but is seems all my holes vary.
The holes in the running boards that the bolts pass through is larger, so the running board can move up or down.
Donovan D wrote: Wed Feb 05, 2020 6:27 pm
Thanks Donovan that helps looks about 45mm
Thought you were after the height of the bolt holes.
