Beetle window washer
jacquesbotha
What model do you have?: 1973 Beetle 1600
Has thanked: 7 times
Post by jacquesbotha »
Has anybody changed the window washer on their Beetle to an electrical unit? How did you do it, and parts from which vehicle did you use? I'm thinking of using the reservoir from a MK1 Golf, and fitting a microswitch to the wiper/washer stalk on the steering column, where the normal valve is, and just add a relay in line to be on the safe side. I've seen a lot of good ideas on The Samba, but we all know that the overseas models were vastly different to the SA models.
Re: Beetle window washer
You can get the full kit from Midas
With installation instructions.
jacquesbotha
retrovan wrote: Mon May 18, 2020 8:53 pm You can get the full kit from Midas
Will have a look into that, thanks Herman.
John Alves
Been thanked: 48 times
Post by John Alves »
I used a mk1 golf bottle with internal pump.
switched under dash worked well
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
jacquesbotha
John Alves wrote: Tue May 19, 2020 12:45 pm I used a mk1 golf bottle with internal pump.
John, where did you mount the bottle, maybe a pic or two if you have?
John Alves
jacquesbotha wrote: Tue May 19, 2020 4:15 pm
I don't have that car anymore, but as far as I remember it was mounted to the side near the hinge spring and brake fluid reservoir.
I think I used the rear window washer from the golf, might be smaller than the front one. It was a long time ago so the memory fails me
1968 1500 SP Beetle
