Line bore advice
wilnic
What model do you have?: 1974
Line bore advice
Post by wilnic »
Ok so I am rebuilding my son's 1600 twin port beetle.
The case needs a line bore. Rear bearing got knocked around quite a bit due to end play. Have any of you guys use an engineering shop in PTA area that knows what they are doing? Yesterday morning I went to Volkspares in van der Hoff road and the shop that they used in the past closed down. Up to what mm bearings do you get?
AlanH
Has thanked: 125 times
Been thanked: 86 times
Germany
Re: Line bore advice
Post by AlanH »
Not in Pretoria but Vdubtech do it.
Just use the search function on here.
Found it.
viewtopic.php?f=83&t=38965
Wanted parts:
Left sunvisor
Sink faucet
wilnic
Post by wilnic »
Awesome, thank you!
