Autovilla
Autovilla
So bought my 1st Autovilla today
In need of alot of work
Not been running for 4 years
Will see if I can get it running with the v6 and go from there
I do have the 2Wd long ratio transmission out of my Rotary turbo double cab with Vacuum difflock I could install
So any Autovilla literature available and willing to share
Please do post and share it here
According to vin 25c this is a 1983 modelImageImageImage
Camshaft
Been thanked: 107 times
Re: Autovilla
Post by Haans »
For crockery ! .......talk to Sean !!!!!😂🤣😂
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Re: Autovilla
Post by Terry Phillips »
Pierre I still have that CI camper shell you cut the fenders off, it still has a few bits and wiring harness, and a few other bits if you are interested. It still has the pop up roof the one you open the side panels but the roof needs work.
PM me.
Re: Autovilla
Terry Phillips wrote: Tue Aug 04, 2020 2:20 pm Pierre I still have that CI camper shell you cut the fenders off, it still has a few bits and wiring harness, and a few other bits if you are interested. It still has the pop up roof the one you open the side panels but the roof needs work.
PM me.
:D :D Thanks Haans
erry is that bus on Wheels to take away
can you whatsap me some pics pls 0826008663 then I can take it from there
Terry Phillips
Zambia
Re: Autovilla
Its on wheels but I must check as I did use the discs but cant remember whats all there I will check and come back to you with some pictures. I fitted the power steering on my Kombi.
