IS THIS A 1700 OR 1800 CONROD
Cyndi Kritzinger
Facebook: yes
Been thanked: 64 times
Post by Cyndi Kritzinger »
HOWDY ALL.
I AM TRYING TO DETERMINE IF THIS IS A 1700 OR 1800 CONROD.
I AM NOT LOOKING FOR GUESSES IF YOU DON'T MIND. 61.9 KB WhatsApp Image 2020-08-09 at 13.48.46.jpeg Check Error
Edmond
Has thanked: 22 times
Been thanked: 38 times
Re: IS THIS A 1700 OR 1800 CONROD
Post by Edmond »
Looks like a 1700/1800 Conrod according to the Tom Wilson book
Been thanked: 100 times
I guess Edmond is not guessing...
sean
Has thanked: 63 times
Been thanked: 227 times
Post by sean »
Hi Mark
What is the ID of the bush where the gudgeon pin goes through? You get 2 different 1700 rods that utilize different pistons.
Cyndi Kritzinger
Facebook: yes
NO IDEA SEAN; I'LL HAVE TO MEASURE.
I ASSUME FROM YOUR QUESTION THAT THIS IS INDEED A 1700 CONROD THOUGH......
WHAT IS THE DIFFERENCE IN THE PISTONS AND WHY?
sean
Post by sean »
Cyndi Kritzinger wrote: Tue Aug 11, 2020 4:08 pm NO IDEA SEAN; I'LL HAVE TO MEASURE.
That appears to be a 1700, but it’s only based on a picture. Measure it to know properly.
Cyndi Kritzinger
Facebook: yes
@ SEAN.... AND ANYONE ELSE THAT KNOWS THEIR STUFF.
CENTER TO CENTER 12.5CM (125MM)
COMPLETE LENGTH TOP OF NIPPLE TO BOTTOM OF CONROD 19.5CM (195MM)
If you read the above explanation then you have the tall balancing pad (Square thing on top)
So you have the 1700 con rod
The 1800 has a small bump balancing pad on top, as per photo, which you have not got.
OMO
sean
Post by sean »
Here is a pic below of 3 different rods I’ve taken. 1.7, 1.8 and 2.0.
Cyndi Kritzinger
Facebook: yes
I'M FAIRLY SURE MINE IS A 1700 BUT THE ENGINE/BITS WAS/WERE SOLD TO ME AS AN 1800, HENCE THE UNCERTAINTY.
I DO REALISE THAT A LOT OF PEOPLE DON'T KNOW TOO MUCH ABOUT THESE THINGS.
As most books will only give you a guide, you will have to measure and measure and measure to make sure you have the right collection of parts to fit into one engine.
As so may hodgepodge motor's are out there with a mix and match parts list, you can not be sure what you have without measuring.
Good luck old boy.
