Hi there,
I have a 1303 1973 LHD, I am put it back and discovered that the arms are different in lenght but the blades are the same 320mm.
I saw that they sell also 380mm blades.
So I am wondering what is the correct position for them, there are no marks for left and right and I was thinking to put the longer arm on the passenger side with the 320mm blade ( no room for the 380mm with the long blade) and the short arm with a 380mm blade in front of the driver ( there should be enough space.
Any ideas ?
Thank you
1303 wiper arm
maggiolo72
- What model do you have?: 1303
