Rev counter connections
- Been thanked: 98 times
I have a old 2002 BMW Rev counter that I intend on fitting to my engine stand, it has 3 terminals marked + 1 - what goes where? I don't want to risk poping it so any help would be appreciated.
- Merlin
- Has thanked: 20 times
- Been thanked: 39 times
Hey Rui,
On that subject, I've go an idea for a tachometer...
1. Do any of you here know someone into their electronics with a penchant for cars? It's a rather unique and complex idea, so I need someone who knows what they're doing...
2. What's the word on the revs with my new engine? Redline, power, etc.?
Obviously, afaik, the stock idiot marks on the speedo will no longer apply.
Thanks, N.
Thanks, N.
can someone explain those marks?I'm still trying to figure out on the two Beetle speedo faces that I have at homeMerlin wrote:Hey Rui,
Thanks, N.
- Merlin
They're "idiot marks"...safe maximums for the revs you're pushing out with a stock engine.
Nic, with the cam that is going in it will make power to about 5300 RPM will be no point in revving much higher than that, a rev limiting rotor will be a good investment max out at 5800 RPM, the motor should pull around 95 to 100 HP, but it will be very torquey due to the larger stroke, going by the previous stroker I had it will be a real stump puller, pulling away in second gear will be a breeze, remember this is a conservative setup, and very drivable, it will idle like a stock motor and have power right off idle. the idiot marks on the speedo will be passed before you have a chance to see them
- Been thanked: 322 times
- Merlin
I don't have a rotor to swop, but I'm interested Fig...I presume this fits without hassles to that Pertronix, Rui?
Where can It one, locally, to swop you with Fig?
- Merlin
Shot. Is that a decent limit to top it off at in term of preserving reliablity and longevity?
Will go shopping soon...
A stock 1600s topping off aarnd 4,500 right?
Thanks, N.
Thanks, N.
- Single Port
- Has thanked: 13 times
ok, I will give it a go.... I have an old tacho, and it workks on a loop that comes from the coil, but then has 3 wires as well +ve, -ve and the light.
If its a newer type, there is a signal wire, +ve and -ve, but should be another one for light.... but maybe the body needs to be earthed. in which case it would be signal, +ve and light....
I think they are pretty hard to break....
- Has thanked: 45 times
- Been thanked: 208 times
German vehicles use numbers for automotive wiring. 31 is earth,15 is switched positive (when the ignition is on) and 1 is the wire between the points and the coil. On a Bosch coil one usually finds the number 15,which is black and comes from the ignition switch.There is also the number 1 next to the other terminal. This goes to the points and condenser,and is also used as trigger for the revcounter.
Would say + is 12 volt, 1 goes to points and - to earth.
Just beware, VDO made a special revcounter that was used in the SP beetle.It was triggered differently,so that an extra wire to the rear was not neccessary. It sensed current change instead of voltage.It was connected so that the current from the ignition switch passed through the revcounter on its way to the coil terminal 15.The light was in a holder that could be removed.
