The Solex 34 Pict 3 on our 1600 TP buggy is toast... Vacuum leaks all over, mostly on the throttle shaft, verified by spraying carb cleaner onto the shaft while running.
The result is a very erratic idle and rough running that simply cant be adjusted and run for more than a single outing before needing a tune again
I am looking to get a replacement, I can't afford the 6 K original Solex and am then looking at whether I should be going for something like the 32/36 weber or 40/44 Idf carbs. I wish to stay single carb centrally mounted and I know this would need a new inlet manifold.
Fuel economy is not the main focus, but I obviously don't just want to pour raw fuel into the motor....
I have an almost new SVDA dizzy to go with it if suitable as well.
All other elements of the motor are standard and we plan to fit a 4 into 1 exhaust in the next few months.
Any thoughts or suggestions or even leads in one of these that would be suitable at a reasonable price?
Thanks as always, Keith
