Head work on 1600 TP to run dual DRLAs
TheRookie
What model do you have?: Not yet
Post by TheRookie »
Hi Guys what affordable headwork can i do to run a set of 36 DellOrtos DRLAs to get decent power .
The motor will be stock .
Is it advisable to fit a breather box too
Thanks in advance
Re: Head work on 1600 TP to run dual DRLAs
no breather box needed unless engine is tired and needs a rebuild.
I occasionally port heads for higher HP numbers. Twin dells, ported heads and a decent exhaust usually end up around 70 to 75hp, if tuned properly - so thats about 50% over stock and completely reliable.
