Spark thread insert
Carl1234
- What model do you have?: 1971 1300 beetle
Spark thread insert
Hey everyone I was wondering if somebody knows where I can get an insert inserted into my 1300 engine. I have noticed that the spark plug thread is stripped and would prefer to not get it helicoiled as I have heard that those are unreliable. Upon contacting volkspares there are aprently no replacement head units for the 1300cc right thanks a lot.
- sean
- Has thanked: 63 times
- Been thanked: 227 times
Re: Spark thread insert
Hi. A Helicoil can be used successfully. I agree, it’s never the best alternative, but they work.Carl1234 wrote: Tue Dec 07, 2021 10:09 pm Hey everyone I was wondering if somebody knows where I can get an insert inserted into my 1300 engine. I have noticed that the spark plug thread is stripped and would prefer to not get it helicoiled as I have heard that those are unreliable. Upon contacting volkspares there are aprently no replacement head units for the 1300cc right thanks a lot.
Inserts on the other hand are disastrous. Those things are pressed in and knocked tight. Will most probably cause hot spots and pre detonation.
The best alternative is to weld up the hole, drill and retap.
